Revit 2019 DWG export layer issue
2 ANTWORTEN 2
Nachricht 1 von 3
MTRA
256 Aufrufe, 2 Antworten
I am currently working on a renovation project that needs DWG export following a specific DWG graphique charte. The project being separated in two models (existing and new), I don't seem to be able to get the floors from the linked model to go into the correct layer. The modifiers used are Phase/Floor/Function, to achieve: AC - Existing - Floor (for finishes) or AC - Existing - Structure (for slabs)(see image). The modifier and export works perfectly for floors in the main model. Anyone has had issues with linked models?
Many Thanks.
Tags (3)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: MTRA
What about exporting linked files as separate IFCs?
Nachricht 3 von 3
MTRA
als Antwort auf: barthbradley
Thanks for your reply.
I tried to have the existing model as an IFC model, but I seem to lose the phases of the project in the IFC and it ends up putting everything as new even though the existing phase is selected as the export phase.
