Revit 2019 does not remember the position of Properties and Project Browser
7 ANTWORTEN 7
Nachricht 1 von 8
alex60
1620 Aufrufe, 7 Antworten
Hi all, I have installed Revit 2019 and during the installation received a message of Error 1946. I do not know if this error is the problem that makes Revit does not remember the position of the Properties and Project Browser in the second monitor. I repaired the installation but nothing happened.
If someone has the answer for this issue, will be appreciated.
Thanks in advance, Alex
7 ANTWORTEN 7
Nachricht 2 von 8
cbcarch
als Antwort auf: alex60
Take a look here:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 8
ross.timm
als Antwort auf: cbcarch
Thanks, but that link takes you to a very weak discussion on this Revit.ini file, with a tons of categories and none that appear to solve this particular issue.  Lots of ways to screw up a revit installation though, and probably not setting that can be modified except by IT staff in my corporate world.  This should be an easy checkbox i.e. "remember window position".. simple... not some hacker crap
Nachricht 4 von 8
terryjob
als Antwort auf: ross.timm
Was this problem ever resolved? I just installed Revit 2020 and am having the same problem with the browser and properties window.
Terry
Nachricht 5 von 8
mcumminsEVQ4M
als Antwort auf: terryjob
Close Revit. Search for your Revit.ini file, rename it something like Revit-old.ini.  Reopen Revit, move your boxes where you want and close and reopen.  It will write a new Revit.ini and should solve the problem.  If it works, delete the old file.
Nachricht 6 von 8
narlee
als Antwort auf: mcumminsEVQ4M
Thanks for that! (had same problem)
Best,
Geof
Nachricht 7 von 8
david
Thanks @mcumminsEVQ4M , this solution worked for me
Nachricht 8 von 8
DGeorgeGCZD2
Got a new computer and R23 was giving me this problem (had R23 on last one with no issue). Deleting and creating a new .ini file did not solve my problem.
