This message appears when I try to open this project in Revit 2019:
The project was created and it opens with no problem in Revit 2018 as follows:
I have tried to delete almost all families and I have been purging it and saving it every time, but always same message.
Anyone knows what is happening ?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
.... welll the only way to save the project was going 3d and copying the entire scene
... after that create a new template and pasted the project
... rename levels adjust everything
... and done
aRcHiTeCt.JM
REVIT EXPERT ELITE
ALAS; a solution has been found!!! I've been on pins and needles for months, waiting for a solution to be accepted by the OP.
Congratulations, @aRcHiTeCt.JM. You did it!
@barthbradley wrote:ALAS; a solution has been found!!! I've been on pins and needles for months, waiting for a solution to be accepted by the OP.
..... thank you
aRcHiTeCt.JM
REVIT EXPERT ELITE
