Have been using Revit 2019 for almost 3 months now and finding so many bugs. I use the program for a lot of interior designing, kitchen/bath design so I do a lot of modelling and rendering in the cloud.
1. the icons along the bottom (perspective, detail level, graphic display options, sun/shadows, hidden graphics) often has many icons disappearing and the only way I've found to make them come back is to single-click on a view in the project browser
2. when I type notes I often use short cuts of CTRL+B (bold) CTRL+U (underline) & CTRL+I (italics), they appear fine when working within the program but when I go to print the drawings they do not print, they just print as standard text
3. in Visibility Graphics, line override types and line weights can be set differently than their standard but are not acknowledged in any view
4. Break Lines get cropped with cropped views! This drives me crazy and has not been an issue in previous revit versions. I'd like the break lines to extend past what they are breaking however it doesn't work if your view is cropped
5. Rendering in Cloud - often in the first or second time I render a view to the cloud, it doesn't render photorealistic, it's more like just the "realistic" option that you can work in within Revit
That's the list I've collected for now. Hoping these issues make sense and that this gets noticed by the techs who work on bug fixes.
Hi @LyndsB
Thanks for reporting these issues.
It will be great to have more information from your end on each of these since these are individual issues and sometimes user/ model specific (screencasts, screenshots, and data-sets will be helpful)
I'll be glad to investigate further, once we have your files. Let me know if you can share and I can send you a private upload folder.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Please start a private folder, that would be great.
@Viveka_CD wrote:Hi @LyndsB
Hi @LyndsB
I've just created a private upload folder and shared the link o your email on your profile.
Let me know if you have trouble accessing the folder.
Please see the links below to send us the required files:
screencast of what you are experiencing
Revit - Collecting and sending diagnostic data to Autodesk Technical Support
Let me know if you have questions on the above.
Viveka CD
I believe I have done as requested. Is it possible to communicate with you via e-mail from this point on?
Hi @LyndsB
You can send me a private message (right click on my profile and you can send an IM)
The two PDF's you've posted is for two separate issues, we will make separate posts for each.
Also, I have only PDF's from you, I will require files to test and journals with a data-set as mentioned in my previous post.
Let me know if you have any questions on the same or on how to extract diagnostic data.
Viveka CD
Hi @LyndsB
With regard to your recent communication, I've shared two private upload links to your email on the profile.
I want to see your files to further investigate the issues -
Let me know if you have any questions!
Viveka CD
I have added files once but it wont allow me to add any more. I have the journal as required ready to send to you but I can't add it, there is no option to do so. See screenshot attached.
Hi @LyndsB
Sorry to hear that!
Please look forward to an alternate upload link.
Viveka CD
Hi Viveka,
I have not seen an alternate link yet. Please advise.
Lyndsie
Hi @LyndsB
I've sent you another link again - I hope this works. Can you please confirm?
Viveka CD
Perfect - it appears to be working and i am currently uploading files. They are taking a bit of time but are going. I will check back in once they are complete to confirm you received them.
That's awesome. Thanks for the update, please let me know when you are done uploading these!
Viveka CD
