Revit 2019 bug? - Project Browser shortcuts not working
ldonkle
Message 1 of 32
ldonkle
In previous versions of Revit, I could jump around the project browser by typing the first couple letters of a view.
Seems to not work in Revit 2019. You can do it once per Revit session and it immediately stops working.
Is there a fix?
Replies (31)
Message 2 of 32
Viveka_CD
Hi @ldonkle
Can you share a screencast? This will help us investigate further.
Are you using multiple monitors?
Can you try a repair of Revit and see if that helps resolve this issue?
I look forward to your reply update.
Message 3 of 32
Viveka_CD
@ldonkle
In addition to the above post, if your issue persists, please try the reset option for me and let me know if it helps!
Message 4 of 32
ldonkle
Screencast posted.
I am using multiple monitors - but I turned off all but 1 monitor and restarted, and still had this issue.
I also tried to reset the ribbon/toolbar/browser but had a 2 problems.  I don't see the registry key it says to edit (see attached screenshot).  Also the file "ResetUI.zip" is missing 2019
Message 5 of 32
Viveka_CD
Hi @ldonkle
I'm sorry to hear that the issue persists.
Can you please reinstall Revit 2019?
See this article for more information on clean uninstall and reinstall.
Message 6 of 32
ldonkle
Done.  Still has the issue.
I have also installed Revit 2019 on a brand new laptop and it has this issue as well.
Message 7 of 32
ldonkle
Hi, any other solution to this?  My issue persists
Message 8 of 32
Viveka_CD
Hi @ldonkle
Can you confirm if your system requirements and hardware tools are compatible to successfully run Revit?
Message 9 of 32
ldonkle
Yes, I have verified (both this computer and my laptop) do meet all the minimum requirements to run Revit, and both have this issue.
I'm confused.  Am I really the only one having this problem?
Message 10 of 32
Viveka_CD
Hi @ldonkle
I'm sorry to hear that.
Can you send me a journal and a screencast of what you are experiencing?
Do you have a multiple monitor setup and can you clear your temp folder and see if this happens?
I can send you a private upload folder, let me know.
Message 11 of 32
ldonkle
Screencast attached.  I have cleared my temp folder, and turned off all multiple monitors and still have the issue.
Message 12 of 32
ldonkle
Message 13 of 32
I am having the same issue.  Found this thread.  Not ideal, but better than scrolling through the list to find what you need.
https://forums.autodesk.com/t5/revit-architecture-forum/finding-drawings-in-project-browser/td-p/568...
Message 14 of 32
stingers80-cgarchitect
@Viveka_CD wrote:
Hi @ldonkle
I wonder if this issue has been 'Confirmed' and/or 'resolved' already. I'm having the same problem.
Message 15 of 32
denise.lollar
Im having the same issue in 2019. I cant get out of "Edit Assembly" mode without undoing, so I tried adding in a keyboard short cut, nothing happens.
Any fixes without asking the same question about how many monitors I have or if I have emptied my temp files since those dont actually have any impact on the issue?
Message 16 of 32
pieterschiettecatte
We're having the same issue here (Revit 2019.1)
I used to be able to jump to furniture by clicking on families and then hitting F (or W for walls for example). This doesn't work anymore in 2019.
Message 17 of 32
laura
Observer
Observer
I am having this same issue. I've read through this thread. I have the same monitor setup, hardware, etc as I have for all other versions of Revit.
I can get ONE shortcut response per Revit session. So if I type "SH" for sheets, it will go. But, it will only go once... then there is no more response to the shortcut.
Just following in case someone resolves this.
Message 18 of 32
ldonkle
I've noticed you can "refresh" shortcuts by having 2 projects open.
Ex.
Open 2 projects.  Type "SH" for sheets in Project #1.  Then click on an open window of Project #2.  Then go back to Project #1 again.  The shortcuts will work one more time.
Message 19 of 32
Viveka_CD
Hi @laura  and others with the same issue,
Let me escalate this to the development team for further feedback.
Message 20 of 32
Viveka_CD
Hi @ldonkle
I'm waiting for feedback from the development team and will let you know if I will need more information.
