Revit 2019 Adding Centerline Symbol in Dimension Text using Arial Font
4 ANTWORTEN 4
Nachricht 1 von 5
tturnerJBN46
6903 Aufrufe, 4 Antworten
Using Revit 2019 and trying to add Centerline Symbol in Dimension Text using Arial Font. It just shows a box. Does the Arial font not support the CL symbol.
Please advise.
Thanks in advance.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: tturnerJBN46
That is not from the font used.  You need a Generic Annotation Family.
If you want to use Arial letters, just create your own family and use C and L letter from the Arial font (see attached family).
Nachricht 3 von 5
Karol_Piroska
Seems to work just fine.
Nachricht 4 von 5
tturnerJBN46
als Antwort auf: Karol_Piroska
Thank you for the quick response. I apologize for not stating my post clearly. I meant that I wanted to add the symbol in the Dimension Text dialog box. It shows up as a box when I try to use Arial font. I have added an attachment.
Nachricht 5 von 5
Download the family above, load it in your project and assign it to the dimension style's center symbol.
