Hi All
Does anyone else have problems rendering with sketchy lines enabled? is it possible?
Cheers
You may try this..1. 3d View - change Walls into 100% Transparent
2. To hide the wall lines ( cause its going to look like wireframe ), use invisible lines in " Line Work "
without linework - transparent wall
with linework..
Best luck
hello, still not possible rendering with sketchy lines. only good for 3d View. thanks
