Revit 2018 UI's Not Working
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
KraiggC
383 Aufrufe, 2 Antworten
We have just encountered a rather debilitating issue. The Project Browser and Property Panes have become unresponsive. No matter what we do, we can't use them. We can't click the "X" to close them, can't move them or navigate within them. We've restarted everything, tried repairing the program, even uninstalled and reinstalled. The properties pane can be worked around for now, but with the use of the Project Browser we're dead in the water. Please Help!
2 ANTWORTEN 2
Nachricht 2 von 3
Matt__W
als Antwort auf: KraiggC
Try the following to reset Revit to its default settings (an uninstall may not have removed all of the registry settings).
Rename the UIState.dat file located in the following folder to UIState.old: %APPDATA%\Autodesk\Revit\Autodesk
Revit {Product Name}\ENU
Navigate to and rename the following directories:
OLD NAME: C:\Users\\AppData\Local\Autodesk\Revit\Autodesk Revit 201x
NEW NAME: C:\Users\\AppData\Local\Autodesk\Revit\Autodesk Revit 201x_backup
OLD NAME: C:\Users\\AppData\Roaming\Autodesk\Revit\Autodesk Revit 201x
NEW NAME: C:\Users\\AppData\Roaming\Autodesk\Revit\Autodesk Revit 201x_backup
Open the registry editor (Start > Type REGEDIT hit enter)
Rename the following registry key:
OLD NAME: HKEY_CURRENT_USER\SOFTWARE\Autodesk\Revit\\Workspace
NEW NAME: HKEY_CURRENT_USER\SOFTWARE\Autodesk\Revit\\Workspace_backup
* Replace with the Revit version, such as "Revit 2018". Once those are renamed, restart Revit again.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Nachricht 3 von 3
KraiggC
als Antwort auf: Matt__W
This worked, thank you so much!
