Hi there.
I'm aware that this topic has been covered extensively however does not seem to help with the question i have.
I cannot seem to find the template files and libraries even when i attempt another installation it says that those are already installed. I've gone to the default path where these files are normally located and they are not there and i've checked 'hidden files'. C:\ProgramData\Autodesk\RVT 2018
Is there any solution for this or should i attempt another installation? I've done the installation from my account.
Andre Wiese
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
Please ensure all residual files are properly removed as well, before you attempt a fresh reinstall.
Follow the solution steps on this article:
How to Complete a Clean Uninstall and Reinstall of Revit products
Let me know if you have any questions!
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi there.
I managed to follow those steps last night and worked, but thanks for your response.
Kind Regards,
Hi @Anonymous
Glad to hear!![]()
Also, check this post for related information on Revit content.
Viveka CD
