I just installed Revit 2018 from the Design Suite subscription I have. The Structure tab (along with the typical Revit tabs) was provided. There is not a System tab for the MEP portions of the Ribbon. I had this on the past few editions of Revit I had. Is this a bug or a bad install? Is it not offered anymore?
Gelöst! Gehe zur Lösung
Gelöst von PijPiwo. Gehe zur Lösung
Go to application menu -> option -> user interface, and make sure system tabs are checked (all three of them).
Thank you! Thank you! Thank you! If I could give more than one Kudos, I would! Much appreciated...and, then some more to a fellow beer lover!
