Is the Revit 2018 Stl exporter available and if so how do I download it?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Gelöst von zhukoven. Gehe zur Lösung
This is all that I could find - for Revit 2017
https://apps.autodesk.com/RVT/en/Detail/Index?id=1223946382495494802
@Anonymoushello, if you have a autodesk subscription you can download from your account. thanks
Hi @Anonymous
I see that you are a new visitor! Welcome to the Autodesk community! ![]()
Let us know if you have any additional questions. Happy to help!
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
Thank you,
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Can't see that this is a solution. Linking to a post saying it's possible to download plugins? As far as I can see there is still no .stl exporter for Revit 2018 or am I missing something?
Sorry that the links I provided in my previous post were not direct, but these have a series of links that take you right there as mentioned by @zhukoven
@zhukoven you are spot on!![]()
The first link takes you here: Install Updates, Add-ons, and Enhancements
Then from the management link - search for product updates - STL exporter
Cheers!
Viveka CD
@Viveka_CD Do you know the reason it't been moved from autodesk app store to subscriptions? Apps under subscriptions are much harder to get since it's not available to all users, especially in large organizations.
Hi @Magnus.B
Yes, the availability for the Revit 2015, 206, 2017 STL exporters are on the appstore and Revit 2018 STL on the account page.
I have forwarded your query to the product team responsisble for appstore extensions. I'll update if I have futher feedback from the team.
Viveka CD
Hi there @Magnus.B
Here's an update from the Revit product team for why certain apps are moved from the Autodesk app store to subscriptions/account management.
Viveka CD
@Magnus.B Yes it is, and do let us know if you have additional questions!
Viveka CD
MY MANAGEMENT web interface does not list the stl converter 2018 and the app center only lists a 2017 version.... why can I not get the 2018 version, is there another location or link somewhere else?
thanks
Hi @Anonymous
Are you using the same credentials you've used to request the 2018 version as the same one you're using at this time to log into your Autodesk Account?
Viveka CD
Hi, for some reason even when following your instructions I can't find the STL exporter for Revit 2018. Can you please share a direct link to this add-on?
Thank you,
Max
Hi @maxV2MCX
Are you unable to locate this on your accounts page?
Viveka CD
Hi Viveka,
Thanks for the reply. I tried both, the appstore and accounts page, but no luck finding the STL exporter for revit 2018. Can you please help?
Max
Hi @maxV2MCX
I'm sorry to hear that.
Please see AKN article:
Missing products or updates in Autodesk Account and Autodesk desktop application
You can also post on the Installation and licensing forum for further feedback.
Viveka CD
@Viveka_CD wrote:
Hi @maxV2MCX
I am an educator so we download for free now. In the past, we had to purchase the software. So am I to understand that the ability to save a Revit file as a .stl so we can have students 3D Print their drawing is no longer available? Because I can't find this "add-on". In the past, I believe I could save as a .stl format was an option for when we 3d printed student work.
