Let me start by saying... I screwed up.
Have now uninstalled Revit 2018 (from Building Design Suite Premium 2018)
I was having various issues with the AutoCAD programs from this suite, so I decided to totally uninstall the suite so I may perform a fresh re-install.
I performed a clean uninstall and then deleted left-over program folders and registry entries as suggested.... from guidance this forum provided.
My issue is that I did receive 2 updates in the last couple of days.
1 was Site Designer 2018 and the other was Steel Connections 2018.
After re-installing Revit 2018 I no longer receive the pop-up that updates are available so I no longer have Site Designer 2018 and Steel connections 2018. Although I did receive a pop-up today, that Revit 2018 Extensions are available.
When I log in to my Autodesk account, I see no reference to Site Designer 2018 or Steel Connections 2018.
My question is: and suggestions as to how I may receive these 2 extensions once more?
Suggestions are welcome.
Gelöst! Gehe zur Lösung
Gelöst von Lineabove. Gehe zur Lösung
Gelöst von Diego.Faria. Gehe zur Lösung
Hi Diego,
May I ask if you would also package up Revit Extension for Fabrication 2018?
This seems to be the last missing piece in my install.
Best regards,
Mel
Diego,
Please ignore my last request.
Installation is now OK.
Thank you for your assistance.
Mel
