The project I am working on has 5 active models and they are all linked to a Mastermodel, where the drawing sheets are produced.
I was asked to change the names of the .rfa files in my Active models. For example, I select a door, clicked "Edit Family", "Save As" a new name, and "load into project and close". When I am back in my Active model, I replaced all the same door type to the newly named door family. Just to be clear. They are the exact identical door, just a new .rfa file name. When I synchronise and reload it in the Mastermodel, relevant dimensions/tags would drop off.
Also, some of the same family are replicated in a few Active models. For example, Door Type 01 is in Active Model 01 and Active Model 03.
Would anyone know a better way of renaming .rfa files without compromising its dimensions or tags?
Thank you very much!
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Rename the door family within the project first, then save as to a new RFA. No need for the reload override step.
