Revit 2018 P&ID Modeler Failure at every close of program
4 ANTWORTEN 4
Nachricht 1 von 5
jimiz73
331 Aufrufe, 4 Antworten
Everytime I close the Revit 2018.3 on my windows 10 computer, I get this failure message. See Screenshot.  I have googled and cannot find the exact same issue to be posted.  I do not use the P&ID Modeler but the error is annoying.  Anyone else had this happen to you?  Anyone found a fix to this?
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: jimiz73
it could be installed plug-in programs , try to uninstall and see if helps. thanks
Nachricht 3 von 5
jimiz73
als Antwort auf: ennujozlagam
I cannot find a way to uninstall this add-in
Nachricht 4 von 5
ennujozlagam
if you cannot find your add-in ? try to do a clean uninstall and reinstall again your program and see if helps. thanks
Nachricht 5 von 5
jimiz73
That seems like pain to have to reinstall everything.  I would think that is the last resort but the second one in the forums.
