Good morning, the issue described in Incident ID: 99340 where keynotes disappear from the Keynote legends on Roof sheets is still happening for projects in Revit 2017 and Revit 2018. Both programs are upgraded to the latest version on all user machines.
In Revit 2018, this issue has extended to RCP views as well.
This issue is insidious because we can correct this issue at Q/C, but the tags can disappear any time between then and submission. We must manually check dozens of Roof and RCP sheets - adding a lot of extra work. Sometimes the 'changing view range' temporary fix does not last for one print and Roof sheets must be printed page-by-page and added back into the final PDF.
Is there any permanent fix planned?
This would peeve me too. Could you please post the Link to this Incident ID: 99340? Thanks.
Check if you have Dependent Views. If so, there is a known issue that Keynotes will dissappear from Keynote Legends on Sheets. The "fix" is to open the View, uncheck Annotation Crop, then re-check it. Keynotes will re-appear.
Not sure if a fix has ever been released by Autodesk.
