I am having the same issue when printing my text is overlapping, doesnt matter if i pick pdf or a local printer. My option to roll back the driver is grayed out. I've attached the journal.
Title edited for clarity by @Viveka_CD: Revit 2018 on Windows 10 Bootcamp Print to PDF text issues (Nvidia card)
Gelöst! Gehe zur Lösung
Gelöst von mshoffman. Gehe zur Lösung
Hi @mshoffman
Thanks for sharing your files. I've created a separate thread for you for clarity.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hello @mshoffman
Thank you for posting your files.
I see from your screenshots that the characters get much larger during print/print preview?
Does this happen when printing to any printer? (Physical or PDF?)
If the problem happens with some printers, can you share the specifics of that printer?
Thank you!
Hi @mshoffman
I'm glad to hear that @michael.coviello helped with your case.
Please follow up on this thread with any updates regarding your case. This will help the community seeking similar solutions.
Viveka CD
Michael logged in and it worked fine. I'm not sure if an update happened on my machine to fix it or if it is a display monitor issue as i have multiple monitors. We are going to keep an eye on the issue to see if it happens again but right now it is working properly.
Thanks for the quick update @mshoffman ![]()
For now, I'll mark your response as the solution, but if anything changes, we can continue on this thread.
Do let us know if you need assistance in future.
Viveka CD
