Can We do Massing in Revit 2018 LT?
I always see Mass & Site Tab from Revit in Youtube.
I don't see that on my Revit 2018 LT.
So I am wondering that I can't do massing in LT Version.
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Gelöst von loboarch. Gehe zur Lösung
Gelöst von pendean. Gehe zur Lösung
You're posting in the AutoCAD forum. You should post your Revit question in the Revit forum like this one:
https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133
Area Object Link |
Attribute Modifier |
Dwg Setup |
Feet-Inch Calculator
Layer Apps |
List on Steroids |
VP Zoom Scales |
Exchange App Store
REVIT LT is not REVIT, could that be the problem? Your cheaper lower version's HELP file should tell you all you need to know about what is missing while you wait.
Read this too http://blogs.rand.com/architectural/2016/09/revit-vs-revit-lt.html
Massing tools are NOT part of Revit LT.
Hi @Anonymous
Cool profile name![]()
What mass family are you trying to create? A toposurface?
Unfortunately, Revit LT can be used to open a Revit model with masses but NOT able to create/edit masses @ mentioned by @loboarch
See the following articles:
You can download a trial of Revit 2018, create a mass and open that in your Revit LT
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
Thank you,
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @Anonymous
Yığma aletleri Revit LT'nin bir parçası DEĞİLDİR
Translation: Massing tools are NOT part of Revit LT
Viveka CD
