Hi to everybody,
I'm trying to install Revit 2018 on my pc but when I run the setup, it fails.
I attach copies of the log files. I tried to install turning off the firewall but nothing, it doesn't work.
Thank you for the answers.
MM
Gelöst! Gehe zur Lösung
You should use the Browser Download instead of install now function.
Install now usually fails.
You can find out more at https://knowledge.autodesk.com/customer-service/download-install/download/about-download-methods/bro...
Download these 3 files in the same folder and run. It should solve your installation problem.
Thanks for the answer, i've just tried this method as is explained here: https://forums.autodesk.com/t5/revit-architecture-forum/installation-problem-revit-2017/m-p/6377010#...
but nothing, i saved the 3 files in the same folder and extracted but nothing. It's very strange, i have Civil3D, Navisworks and infraworks on my pc without any problem.
Attached file is the new log report.
Your setup log shows it's going wrong when installing Visual C++ 2005 redistributable package.
You could try installing it by itself.
I'm not exactly familiar which packages it uses, but a little google pointed me to a download here:
https://www.microsoft.com/en-us/download/details.aspx?id=5638
Nothing, i tried installing visual C 2005 x64, but Revit installation doesen't go.
Apparently you need the X86 version:
2018/5/9:12:24:14 Manue DESKTOP-EP28IDN Installing Microsoft Visual C++ 2005 Redistributable (x86)
This is where it crashes in the setup.
There are some other options you can check:
It is probably created by a newer version of the C++ Redist on your system. You could uninstall the Visuall C++ 2005 X86 version and reinstall Revit. Some more info can be found here:
Thank you and sorry me if i made you lost time.
Now installation is going fine, i've installed visual C 2005 x86 and now i have no problems.
No problem mate.
Glad to be of help. Hope it's all a smooth ride from here ![]()
