Revit 2018 inclined floor
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
1040 Aufrufe, 7 Antworten
How do i make an inclined floor with the thickness of the floor getting smaller through the incline? I would like to have 200 thickness on one side and 180 thickness om the other with and the incline should be -20.
7 ANTWORTEN 7
Nachricht 2 von 8
cbcarch
als Antwort auf: Anonymous
A few methods:
-Model in-place>Extrusion.
Sketch the profile needed, then create the floor., Grip edit length in Plan view. Set Family Type to Floor.
-Use an in-place Void to cut a floor that is level.
-You could also try to use a Ramp.
-You can use edit sub-elements/points to give the top surface of the floor a slope as needed.
-You can use a slope arrow ( this will "tilt" the whole floor, top and bottom surfaces)
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 8
Create a 200 mm flat floor and edit sub elements to bring the end edge down 20 mm.
Nachricht 4 von 8
als Antwort auf: ToanDN
Can't i just change the elevation at the bottom? As in the picture, but how do i change the setting when it is grey?
Nachricht 5 von 8
See below.  And if you read my first post carefully you would notice I said "flat floor".
Nachricht 6 von 8
How'd I do @Anonymous?
Nachricht 7 von 8
Nachricht 8 von 8
Thank you that worked :grinsendes_Gesicht_mit_lächelnden_Augen:
