Revit 2018 DWG Export phases issue
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
428 Aufrufe, 3 Antworten
I´m working on a rebuilding project that is divided into two different phases on the same plane. When the first phase is built we will continue whit building the second phase. The problem i have is that i want to create a export view that contains phase 0 (existing), phase 1 (first phase) and phase 2 (second phase) but i want to show both phase 1 and 2 as new in the phase filter with hatched walls. If i put the view in phase 2 only bulidning parts of phase 2 will be shown as new, becouse building parts from phase 1 will already be existing. Any ideas how to solve this?
cheers!
3 ANTWORTEN 3
Nachricht 2 von 4
Ilic.Andrej
als Antwort auf: Anonymous
You can use a rule-based filter to compensate for the lack of the additional phase filter functionality.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 4
als Antwort auf: Ilic.Andrej
Wow thank you dr Grozozo!
Did you make that clip now?
Nachricht 4 von 4
Ilic.Andrej
Yes :leicht_lächelndes_Gesicht:
Andrej Ilić
MSc Arch
