revit 2018 dont run
revit 2018 dont run
revit 2018 dont run
hello guy
pls help me, error when startup and show this.
you can see my jurnal file at attachment file.
 hope anyone can help me
ennujozlagam
@Anonymous Is your computer specs meet the requirements to run Revit? Try to go to your computer desktop right click Revit icon and choose run administrator and see if helps. Thanks
thk for relpy bro,this pc use for computer lab and run with high spe cpu Xeon E3-1281 processor,8GB RAM
 and NVIDIA Quadro K600 graphic card.already run revit 2017 before this.
do you have any solution or trick
markcalloway
Hi @Anonymous
Here are a few suggestions/questions:
hopefully one of these will help.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
Viveka_CD
Hi @Anonymous
Welocme to the Autodesk community!
From lookiing at your journal, you don't have the latest update for Revit 2018. You have a valid educational license.
As the first step,I would suggest checking the Desktop App to see if there are any Revit updates available. For information on using the Desktop App see the following article: About the Autodesk Desktop App
Note: If you are not able to download updates through the Desktop App, the following article has information on downloading updates through the Autodesk Accounts page:
Install Updates, Add-ons, and Enhancements
Let me know if this helps resolve your issue.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
