Hi may be any one can help me. I have some problem with Revit 2018.
Here is a lot of things I miss in my program, such as Annotate Repeating detail I see only one Briks and nothink more, some families as group not in Revit and some other thinks like tag only one type and etc. what to do?
Thanks in advance.
Most of those things that are loaded/created depend on the template you start with. If you start with the out of the box Architectural template there is only on pre-defined repeating detail, which you can then edit and duplicate to create others...of course this requires that you have the profiles needed loaded.
Tags are again...something that would be pre-loaded in the template....you can load others as needed.
Groups aren't generally pre-defined, but that can vary by template.
