Revit 2018 Command Failure
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
414 Aufrufe, 5 Antworten
Can anyone help me troubleshoot this error. Never seen this before. Trying to place a piece of furniture to the layout and keep getting this messageREVIVT ERROR.JPG
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Disable or uninstall the Furniture Manager add-in maybe?
Nachricht 3 von 6
als Antwort auf: ToanDN
I will give that a try thanks.
Nachricht 4 von 6
Didnt' work thanks for the input.
Nachricht 5 von 6
ennujozlagam
hello, try to edit your furniture family (you downloaded this family or you created your own?), delete as much as possible information that are not necessary in the properties > edit type and see if helps. thanks
Nachricht 6 von 6
Viveka_CD
Hi @Anonymous
This error is common when the add-in is outdated.
Please see if you can run a newer version and if its compatible with Revit 2018
