Can't edit worksets because Owned by another user - it then list my computer as the other owner - nothing has changed on the computer since the drawing was made on this computer.
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Make a note of the 'other' username
Click on the R>>Options
Switch your username to the 'other'
Open the project and relinquish.
Click on R>>Options again and change the username back to your regular username.
You should be out of that cycle now.
Hi @jsf
The best solution is to have the user synchronize their local model (relinquishing borrowed elements)
Note: When this error occurs on opening a model, avoid using the Place Request button as there may be more elements affected than identified in the error dialog, and if the first person to encounter the error borrows part of the elements that need to be changed you can get into a loop where no one can open the model (because multiple people have to relinquish elements before the model can be opened).
If the user is not available, there are a couple approaches to moving past this error, see HERE
Thanks for your suggestion @Sahay_R !
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
