Revit 2018.3
3 ANTWORTEN 3
Nachricht 1 von 4
267 Aufrufe, 3 Antworten
Revit 2018.3
Can I work using REVIT 2018.0.0.420, while my partner is using Revit 2018.3 ?
Can we share files with different updates?
Thank you for your attention
Regards
David
3 ANTWORTEN 3
Nachricht 2 von 4
cbcarch
als Antwort auf: Anonymous
You CAN, but you SHOULD NOT--as the file may become corrupt.
Best practice is to have all users on EXACT same build.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 4
DarrenP
agreed is there a reason you can’t install the 2018.3 update?
DarrenP
Nachricht 4 von 4
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!
It is recommended that all users are on the same build - they come with a  number of hotfixes and patches and helps minimize model data corruption.
To make sure that the issue you are seeing is not something already fixed in one of the product updates, I would suggest checking the Desktop App to see if there are any Revit updates available. For information on using the Desktop App see the following article: About the Autodesk Desktop App
Note: If you are not able to download updates through the Desktop App, the following article has information on downloading updates through the Autodesk Accounts page:
Install Updates, Add-ons, and Enhancements
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
