Are there any compatibility issues between Revit 2018.3 and 2018.2? I'm considering upgrading to 2018.3, while my consultants are still on 2018.2.
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
... as long as I know there will be no issues
... it will be a problem just when you upgrade from year to year version as you can't save backwards
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
i would keep everyone on the same build due to being different build numbers it may cause file corruption later
DarrenP
