I have followed the steps found online that explain how to create an illuminance plan view. It indicates that you select to create a camera, uncheck the perspective box, and then place the camera anywhere in the view. The directions then say to use the view cube to orient to a top view and then set the eye elevation at the desired cut plan and set the target to some distance below the desired level. I have tried this repeatedly and the view will not "get inside" my model. It always looks as if I am above the roof no matter what I set the eye elevation to. I tried the process a couple of times and can't seem to get it to work.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Place your camera in an elevation view so you can point it down. Then go to 3D view cube and orient the view to the Camera 3D view name
...sorry, I think I misunderstood. You need to lock your 3D view to be able to adjust eye and target with non-perspective camera views.
