Revit 2017 Worksharing Monitor Location
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
GlenJNorris
415 Aufrufe, 1 Antwort
Is it possible to specify the exact location of the monitor window on start-up as it defaults to the middle of the screen?
Glen
1 ANTWORT 1
Nachricht 2 von 2
Viveka_CD
als Antwort auf: GlenJNorris
Hi @GlenJNorris
You could try putting your windows to a region using this app HEREThe worksharing monitor defaults to the center of the screen, but you can use options on the General tab to specify the following:
  • Whether the Worksharing Monitor window always stays on top of other application windows. This option makes sure that you see new information as it becomes available.
  • If you use desktop alerts (specified on the other tabs), how long they display on the Windows desktop.
