Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit 2017 will not link or import a DWG file.
2 REPLIES 2
IMCornish
1484 Views, 2 Replies
I am, as usual, trying to meet a deadline but, as usual, computing is letting me down!
I have a dwg file that I need to link or import into my Revit 2017 project but it just is not happening!!
My dialog opens OK
and I can pick the correct file OK
But nothing happens after I have clicked 'Open'
Help please.
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
2 REPLIES 2
L.Maas
in reply to: IMCornish
I have no problems importing or linking dwg in Revit 2017.
Few things you could look at/try
-Try without "current view only" selected
-Place the CAD file somewhere on your local drive instead of network rename it to something simple (e.g. building.dwg)
Open the file in Autocad.
-Is the drawing visible in model space?
-Model located far away from origin?
-Does the drawing make use of (overlayed) Xrefs
-Try to save into a older autocad version
Louis
Please mention Revit version, especially when uploading Revit files.
ennujozlagam
hello, i have also no issue import or link autocad file. you can try to move your cad file to origin 0,0. worse case scenario is to reinstall again the program. thanks.
