Hello Support Team,
What actually i did is "Just open my recent project then go to material editor and edited a material's color then press OK, the n press Ctrl+S to save, Revit just Blink as usual then get message as 'Revit encounter a unrecoverable problem and need to close try to save recovery file..like that'
Why its actually happening?
Its started from yesterday
Please give me a fix..Today i updated revit security update there is no luck to fix this.
Please Provide a Fix
Thanks in Advance
Hopefully
Anshad
@Anonymous hello, you can try to check it here <<click HERE>> . thanks
Welcome to the community:)
Kindly check for the Revit 2017 updates and make sure you are on latest build,
Thank you for the replay,
Actually today morning i updated the revit security update, because its the only one available in Autodesk Desktop App. After that i posted this issue. But when viewing your comment i again checked in desktop app i found update for the App not for Revit. After that update i got new update for Revit. Now i am downloading the same. After the installation and check i will come back to you.
Thanks for the replay,
I will check this and come back to you soon, after the Updates
I Updated to latest version but not fixed the problem
What can i do next?
reset your Revit profile
Navigate to and delete the following directories:
* C:\Users\<username>\AppData\Local\Autodesk\Revit\Autodesk Revit 201x
* C:\Users\<username>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 201x
Open the registry editor (Start > Type REGEDIT hit enter)
Delete the following registry folder:
* HKEY_CURRENT_USER\SOFTWARE\Autodesk\Revit\Autodesk Revit 201x
Once those are deleted, restart Revit again.
Hi, Thanks for replay
No luck..its not resolved. Still getting error and closing
Did you fix your User Profile per suggestion from @ennujozlagam?
Yes i Tried that. Now i think the problem only persist in my ongoing project file, because i created a new project and try to edit the materials and saving is working, so again checked it with one of my old project file and it also working fine. So there is any idea to reset the material editor only as a check, or any idea to recover my project from this issue and check. Because the modeling in almost finished and there is only need to apply the materials, so that i wish to get back the file instead of doing it all again. Please suggest any idea.
Thanks in advance
Anshad
Look at your backups. Copy, rename, and reopen. Some may work, some may not. The trick will be to find the file that works with the minimum loss of data.
Thank you for your replay,.
Actually i already did this all, but not working. I wonder why material editing only cause this issue, any other editing or adding has no problem.?
