REVIT 2017 - Status bar icons display issue
2 ANTWORTEN 2
Nachricht 1 von 3
yara.cp.pereira
201 Aufrufe, 2 Antworten
Hi everyone,
I recently installed Revit 2017 to create some families. But I have been working on projects with Revit 2022, therefore it was installed in my PC in 2021.
I am facing an issue with the display of certain icons, buttons and some of the text in pop up messages. I have attached an printscreen with highlights on the issues to help you understand. Everything else that is not highlighted seems to be in the correct proportion.
I have already tried some of the solutions proposed online (such us trying windows display settings, etc.), but it only works on the icons/text that is already being displayed in the correct size/proportion.
Have you ever faced the same issue? How did you solve it?
Many thanks,
Yara Pereira
2 ANTWORTEN 2
Nachricht 2 von 3
RobDraw
als Antwort auf: yara.cp.pereira
Have you tried lowering the resolution of your monitor?
Rob
Nachricht 3 von 3
yara.cp.pereira
als Antwort auf: RobDraw
I've tried that already. The result is a bigger interface, specially for the icons/text that already appear to be in a normal size.
But no significant change on the icons in the status bar or icons popping up when an element is selected...
Any other thoughts?
