Revit 2017 silent install problem...
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
1200 Aufrufe, 2 Antworten
I have to upgrade to Revit 2017 release on all our Windows 7 64bit stations. I choose network deployment method (the license file is on one of our server). I create a batch script with command lines recommended by AutoDesk. When i run the batch, Revit 2017 setup run silently, Revit 2017 icon appear to desktop computer and Revit 2017 directory appear to Windows startup menu and Program files directory. But after a few minutes, in phase "configuration" of the setup, Revit icon is deleted and all Revit 2017 files into Windows Program files and Windows Startup Menu was deleted !
The installer seems Revit installed correctly but then uninstall it !
I said that we also use AutoCAD and 3ds Max on our computers and I could easily install them with the same method.
I just have a problem with Revit !
I send you here with the logs of the installer if needed.
Best regard
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Note: The script is deployed on the machine and run with the user with administrator rights (through the Runas command).
I just try to run the script by logging me directly on the session for the administrator account and to run it ... Revit 2017 is installed properly !
Strange not ???
I will not spend on each machine and log me on the administrator account to run the script !
I think there is an issue with the 2017 Revit installer because I do not have this problem with the deployment of AutoCAD 2017 and 3ds Max 2017 I used the same method.
Nachricht 3 von 3
In fact I found myself the solution. I had to run my script as loading the Administrator profile (Interactive logon WITH profile). If the script is just run as Administrator, this is not enough !
This is strange behavior of the 2017 Revit installer for AutoCAD and 3ds Max profile loading is not necessary !
Is this a bug in the installer Revit 2017 ?
