Hi All, for the first time for some reason i cannot open my student version of Revit 2017, i have sent a couple of auto generated reports to autodesk but no reply. It seems as i am a student autodesk tells me there is no online support.
As i have end of your assignments due i am at a loss, if anyone could help it would be appreciated, regards Greg
PS below is the error report
Whats the error message when you try to open Revit?
Hi Ganesh, below is the error report, however just now when I try to open the error report does not appear but Revit just continually tries to open. Seems strange as I have been using for 1-1/2 years with no problem at all.
Take 2 --- back to same pop up error now, both pop up error and error report are below
Hi
Try using different user name.
Login to computer using another user and try to open Revit.
It it stills gives problem then its about some corruption at windows level.
I saw this post, might help you out.
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2017-not-opening/td-p/6436943
Cheers
Emptied temp folder, no luck
Run repair mode, no luck
Reinstalled, still the same
Just wont open revit at all, any other suggestions would be appreciated
