Revit 2017 not completely switching language
2 ANTWORTEN 2
Nachricht 1 von 3
298 Aufrufe, 2 Antworten
Hi there,
We are using 2 Revit licenses in the office. One is on a desktop pc, working seemingly as it should. The other is on a high-end laptop and has problems.
I've installed Revit 2017 with everything set to French, however, when opening revit the menu's are all still in English. The templates have switched to the French 'gabarit', but that's about it. The shortcut to start the program is: "C:\Program Files\Autodesk\Revit 2017\Revit.exe" /language FRA
I've already reinstalled Revit, after deleting all the files from the old installation, but to no avail.
What should I do to get the proper language working?
2 ANTWORTEN 2
Nachricht 2 von 3
mpeperkamp
als Antwort auf: Anonymous
Hi @Anonymous,
I will give it a tray to help you.
In the Revit.ini you have to change something:
Revit.ini
I hope it will help you.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Nachricht 3 von 3
als Antwort auf: mpeperkamp
Thanks for your reply.
I have zero experience with .ini files and I'm a bit hesitant to change something. I've attached the Revit.ini file as it was (renamed to .pdf to be able to sent it). Could you take a look?
