I have read the forums and the solutions to the various questions and issues. I have tried little bits and parts of each solution. I have two computers and two problems.
I have one computer that is older that when I installed Revit 2017 (I have previous versions installed on this computer) it comes up with a message: "The path you have specified for the default family template files is invalid" So I can't find any of my families. Also, if I try to create a new wall type with a new material that I am naming and creating it totally crashes and dies. Help!
I have a new computer that is more than adequate to run Revit 2017. The material library installation stops at 264 of ??? every time I try to install it. As I mentioned I have tried everything I have seen recommended on the forums in little bits and pieces. Uninstalled, deleted temp files, tried to do a partial install of just the material library. Nothing has worked.
Thank you. That worked on my new computer. Now I will try on my old computer.
Liquidtime
