dear expert,
kindly advice why my pc system load very slow for 65MB rvt file for REVIT 2017
system - window 10 pro
processor - AMD ryzen 1700 3.0GHZ
motherboard - GIGABYTE AB350M-D3H AM4 MATX
SSD - WD Green 240GB (main drive)
HHD - WD CAVIAR BLUE 1TB (2nd Drive)
DDR4 - 32GB RAM
Thermaltake 750W GOLD - PSU
GPU- GTX1080TI.
I have no idea why i load a 65MB file will take for 5-10mint long. Even after finish load its seem very slow when need to zoom in/out.
Please help.
thanks.
@Anonymous hello, have you try to tick audit before opening the file and untick use hardware acceleration from options > graphics and see if helps. try to install latest updates from autodesk. thanks
Have you got any files linked into your file ? Are you loading via internal network ?
yeah, it have quite lot of link into my archi & structure file. main link is from level04 to 44th storey then the rest of the link is typical unit and PBU toilet layout. rought might link to 15+20 link for superimpose.
i have checked with other subcon who open the same system is quite fast even in lower spect of computer system. this make me have a lot of ?????. and yes, we are loading internal network.
Revit add-ins: Purger (unused line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags), View Filter Manager at Revit Apps Store
going to try this by tomorrow.
thanks.
Hi @Anonymous
Please send us a Revit Journal file to troubleshoot.
There could be several Possible causes for slow performance in Revit ranging from graphic cards to memory to multiple model elements.
Please try the following:
For more information on recommendations to improve slow performance please see HERE
Let me know if you were able to resolve your issue.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos are welcome.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
