Hello
I have some electrical category families, where I have issue creating duplicate in projects created in Revit 2017 because they containing formula. In Revit 2016 they work fine.
The strange is, it is not "with or without formula" issue. What I meen is, that I multiple formulas, but only 1 is the issue.
Here is the formula which is the issue
You can also see parameter containing formulas under Grouping "Other", and they are not getting any trouble. Only the one I marked "Swithboard".
It is not only Electrical Equipment, but also Lighting Device, Ligting Fixtures, Fire Alarm Device etc.
It work fine with different STR categories.
I found a similar post, but with no solution.
Hope you can help
/Simon
Is your parameter a family type parameter or an instance parameter?
Is it set to the same value for all types?
As you can see in your screencast the parameters that are working fine are 'greyed out' the one with the problem isn't.
Can you check for the difference between them.
