Hello, Autodesk Architecture community, I hope you're all doing well.
I've tried opening Revit many times yesterday, & it opened-ish. Whenever I wanted to open an existing or new file, Revit 2017 freezes, & says "Not Responding". I've force-closed many times, & opened it again. The same things happens repeatedly. I waited a long time for a file to open. It never opens, but just freezes. I thought it was my laptop being hot. That's not the cause. I tried opening my file on a different computer. The file opened beautifully & I could work on it.
What's weird is that I've been using Revit 2017 on my laptop for some months. It has opened & worked successfully, & I haven't made any major changes to my laptop. So, I'm frustrated with this problem. I hope there's someone else who's had this problem too.
I don't know if I have to uninstall Revit 2017 & re-install it. What should I do?
Emmanuel
Hi @Anonymous,
What you can do is install the latest updates.
Latest update
I also have here a Autodesk website for more info:
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
When i'm working in Dynamo Revit crashes the whole time when it needs to compute a little more complex mathematical problem. It's always the same with Autodesk products. I reckon the architecture of the scripts are absolutely not written properly. I've never worked with a software that had so many bugs than Revit. I'm totally done with it.
