I have been trying to install the Revit 2017.1 Update to address the resolution issues with schedules.
Every time I try to install it, I am getting an Install Failed. Does anyone know why?
I have attached my log file for reference.
Hi @Anonymous
I was just checking back to see if your Revit2017 installation was successful.
Also I would encourage you to check the following links for error logs & solutions, system requirements, and installation FAQS
Please check the following link for error while installation and the solution provided:
Do check the following link for system requirements:
Installation changes in the 2017 release can be found at the link below:
Let me know if you were able to successfully install or I'm happy to provide you with more information.If you still encounter error messages, we can work on that and find a solution.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
