Hello!
I have a problem, I´m trying to instalate right now Revit 2017 but it apear a message that say that the RCL.msi file is missing.
I have my antivirus off.
Sorry for my bad english
Hope someone could help me, have a nice day.
installation files are bad....redownload the files and try installing again.
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
I reinstalled files 5 times and the problem still continues.
Also clean the temps but the problem still continues
I agree with Dzan that this sounds like the original download of the installation files did not complete successfully. If this is the case, you will see the same problem even if you run the installation multiple times. My suggestion would be to delete the existing C:\Autodesk\WI\Autodesk Revit 2017 folder, along with its underlying content, and then download the web installer again. These actions will result in a new set of Revit 2017 installation files being extracted and hopefully there won't be any missing files this time.
Tony Michniewicz
Autodesk Revit QA
Hi, i have the same problem. I download the files 4 or 5 times, erasing each time the previous files and stil have the same problem. I think is maybe the spanish version is broken ![]()
