Revit 2017 graphics issue with Dell XPS 15 9550
2 ANTWORTEN 2
Nachricht 1 von 3
1151 Aufrufe, 2 Antworten
Hi, I have been having graphics issue with my XPS 15 9550 when I install revit on it. the font sizes are small and non readable and I tried changing the resolution to 175%. when I set in on 200% print options don't work. is it true that Revit is not compatible with 4k laptops. what are my options if I need a powerful laptop for Revit rendering.
2 ANTWORTEN 2
Nachricht 2 von 3
TravisNave
als Antwort auf: Anonymous
The applications have not been developed for 4k.  I assume future releases will be compatible.  There have been some hotfixes released for other products for 4k support.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Nachricht 3 von 3
natasha.l
Hello @Anonymous,
Sorry to hear you are encountering an issue with display of the icons on Revit 2017. How to fix Icon Sizing.
I will also move this post for better support to the Revit 2017 forum so a product expert can provide insight.
Thank you for posting. Smiley (fröhlich)
