REVIT 2017: Create a shell model or make rooms visible in the 3D model and expor
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
Petra.Baumann
760 Aufrufe, 1 Antwort
I would like to create a shell model in REVIT 2017 and export this model as IFC.
1st attempt: create a mass with "project family"
           Problem: The body is partially visible in the 3D model and is not displayed in the IFC file.
2nd attempt: create rooms with "room separation lines"
            Problem: Rooms are not visible in the 3D model, but are displayed in the IFC file.
In general, how can you create a shell model (raster, levels, masses/rooms)? The shell model should be visible in the levels, views, sections and in the 3D model and exported as an IFC.
Thank you for your support!
Kind regards,
Petra Baumann
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Petra.Baumann
When creating 3d rooms, you can regenerate them as "Direct Shapes" in Dynamo, color code them, and create stack diagrams, etc. Marcello Sgambelluri has a great presentation on this. https://www.autodesk.com/autodesk-university/class/More-Practical-Dynamo-Practical-Uses-Dynamo-Withi...
