Revit 2017 Content Library Installation Issue
3 ANTWORTEN 3
Nachricht 1 von 4
551 Aufrufe, 3 Antworten
When I try to Install the Content Library Revit 2017this message appears.
Can anyone help me to solve this problem please? The other two  I have already installed. It is only the Content Library 2017 has the installation issue.
Tharish
3 ANTWORTEN 3
Nachricht 2 von 4
mpeperkamp
als Antwort auf: Anonymous
Hi Tharish,
Welcome to the Autodesk forum.
The following link will help you how to add the content libraries.
Content libraries
If there any questions about it lets it now.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Nachricht 3 von 4
Tony_Michniewicz
als Antwort auf: mpeperkamp
Based on this error, it appears that a required file failed to download and the installation cannot move forward without it. One suggestion would be to delete the contents of your C:\Autodesk\WI\Autodesk Revit 2017 folder and use the Install Now link to launch a subsequent installation. This will force a new set of files to be downloaded by the web installer and hopefully there will no longer be any missing files.
Another suggestion would be to use the Donwload Now option instead of the Install Now option. This approach ensures that all of the install files are downloaded prior to the commencement of the Revit installation. In case you are not familiar with it, the Download Now option can be accessed by clicking the down arrow to the right of the Install Now option.
Tony Michniewicz
Revit Software QA Analyst
Nachricht 4 von 4
TravisNave
Always make sure you also disable your anti-virus when downloading and installing, and ensure that you have local admin rights and UAC disabled.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
