Revit 2017 - Can't change print settings
5 ANTWORTEN 5
Nachricht 1 von 6
2092 Aufrufe, 5 Antworten
I've got something going on with Revit 2017.
I can't change any settings apart from the printer selection. Meaning, everything else fails to open a new window. I can't change 'setup' settings, I can't select a sheet - I can't even preview what I'm printing. All I can do is select a printer. I can hover over any button and it highlights like normal, but when I click it, it does nothing. Even the 'help' button fails to initialize to the website like it normally would.
This is clearly a bug because I've had no issues until now. I tried doing a repair but that failed to fix the issue. Any help?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Further to this, I've just discovered how to recreate the issue.
Devs please find the following:
1. I Can't select any setting or anything apart from the printer. If I send it to my printer, my printer spits it out fine.
2. I go to file> print again
3. Suddenly, everything has come back to normal. I can change settings and do anything I normally would.
4. If I select Microsoft print to PDF, I can do everything as normal. I create the PDF no issues.
5. I go to file>print again, suddenly eveything is unselectable again. But I can fix this by just printing and then going to file>print again after the printer has printed out a page.
So it seems every time I select Microsoft to PDF - it screws something up and I need to print a page to my default printer just to be able to access the settings again.
Hope this helps..
Nachricht 3 von 6
Revit has known issue with Microsoft PDF printer. You need to open Windows printer list, and select another printer as the default printer.
Nachricht 4 von 6
So is there another option for me to create a PDF?
Nachricht 5 von 6
Free: PDF Creator, PDF architect
Nachricht 6 von 6
having this issue with more printers than Microsoft PDF...tried Adobe and Bluebeam, even tried just a real printer.  anybody experiencing this?
