So I'm currently running Revit 2017.1.1. My Autodesk Desktop Application is telling me that I need to apply the Revit 2017.0.3 Security Fix. Should I?
It seems to me if I did I would then be reverting back to an older version of Revit which doesn't make sense. If I shouldn't then why is the desktop application telling me I should? How do I tell the application to ignore this update? This thing worked great for about a year but now seems to be going back to being useless.
Solved by Tony_Michniewicz. Go to Solution.
The Revit 2017.1.1 update is intended for subscription customers and the 2017.0.3 is designed for non-subscription customers. With that in mind, you should not install the Revit 2017.0.3 update if you have already installed either the Revit 2017.1 or 2017.1.1 update. In fact, any attempt to perform this installation should be blocked by the installer.
As far as this update displaying in the Autodesk Desktop App, this update should only be displayed to non-subscription customers but there is a problem in this area that we are currently investigating.
