Revit securrity fixes will not install error message: Install failed - No action taken as a system reboot is required. with log error file as below
[1CC4:256C][2016-12-29T17:58:52]i001: Burn v3.10.2.2516, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\Charlie\AppData\Local\Temp\{493DED60-61E0-436B-9E33-698B44507F87}\.cr\revit_2017_0_3.exe
[1CC4:256C][2016-12-29T17:58:52]i000: Initializing numeric variable 'PRODUCT_INSTALLED' to value '1'
[1CC4:256C][2016-12-29T17:58:52]i000: Initializing string variable 'PRODUCT_GUID' to value '{7346B4A0-1700-0510-0000-705C0D862004}'
[1CC4:256C][2016-12-29T17:58:52]i000: Initializing string variable 'OPTOUT_KB2918614' to value 'NO'
[1CC4:256C][2016-12-29T17:58:52]i000: Initializing string variable 'AdskBundleTitle' to value '[WixBundleName]'
[1CC4:256C][2016-12-29T17:58:52]i009: Command Line: '-burn.clean.room=C:\Users\Charlie\Downloads\revit_2017_0_3.exe'
[1CC4:256C][2016-12-29T17:58:52]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Charlie\Downloads\revit_2017_0_3.exe'
[1CC4:256C][2016-12-29T17:58:52]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Charlie\Downloads\'
[1CC4:256C][2016-12-29T17:58:53]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Charlie\AppData\Local\Temp\Autodesk_Revit_2017.0.3_Security_Fixes.Setup_20161229175853.log'
[1CC4:256C][2016-12-29T17:58:53]i000: Setting string variable 'WixBundleName' to value 'Autodesk Revit 2017.0.3 Security Fixes'
[1CC4:256C][2016-12-29T17:58:53]i000: Setting string variable 'WixBundleManufacturer' to value 'Autodesk'
[1CC4:2FD0][2016-12-29T17:58:54]i000: Setting numeric variable 'WixStdBALanguageId' to value 1033
[1CC4:2FD0][2016-12-29T17:58:54]i000: There is a Beta version of this update already installed. Please remove the Beta version and try this installation again.
[1CC4:2FD0][2016-12-29T17:58:54]i000: 1
[1CC4:2FD0][2016-12-29T17:58:54]i000: Setting version variable 'WixBundleFileVersion' to value '17.0.503.0'
[1CC4:2FD0][2016-12-29T17:58:54]e000: 0x8007015e: No action was taken as a system reboot is required.
[1CC4:2FD0][2016-12-29T17:58:54]e000: 0x8007015e - No action was taken as a system reboot is required.
Also when text is tyed no font size or style is in the properties and when clicked on edit the system crashes.
@Anonymous wrote:Revit securrity fixes will not install error message: Install failed - No action taken as a system reboot is required. with log error file as below
Do you already have 2017.1 installed?
Have you Beta version of this update already installed? Please remove the Beta version and try this installation again.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
