Revit 2016 - Windows won't maximize
I just upgraded to Revit 2016 last week.  Everything seemed to run fine, but this week, whenever I minimize a window, or switch windows (inside Revit - switch views, open new views, etc...) none of the windows will maximize again.  If I click the maximize button the window flashes as if it is maximizing, but then goes back to its position.
Any suggestions?
Nick Laeder
HydroWorx
you could look at this post and see if it helps at all. Also have you done a hard reboot on your computer? and you could to a system restore if you know when it was still working.
https://forums.autodesk.com/t5/autocad-2013-2014-2015-2016/autocad-2016-display-jump/td-p/5699336
Jeff
