Revit 2016 will not work ??
gowsautocad
gowsautocad
I down loaded Revit 2016 and have had problems ever since.  There is lines in the layout and 3D drawing of a project I was working on.  I tried several suggestions with no success.  Not when I try to open the 3D model the system locks up.  See the following attachments to see what is going on. Also note that I still have Revit 2015 on the same computer.  Did not remove it becuase I could not get 2016 to work.  See the attached files and let me know if there are any suggestions or who I can contact to get a solution.
Thanks - Todd McMahon
mcmahont8@mail.gtc.edu
dzanta
have you tried the following:
1.  update graphics driver
2.  turn on/off Hardware Accelleration within Revit
3.  check/uncheck allow navigation during redraw
4.  issue shows up in Revit 2015, 2016 or both?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
gowsautocad
Questions - How do you update graphics driver?
I have tired with hardware acceleration on and off - same result.
I did not redraw - I was just trying to update from 2015 Revit to 2016 Revit
Issue only shows up on 2016 Revit.  File opens fine in 2015 Revit.
Thanks for looking iinto my problem - greatly appreciated
tmcmahon
dzanta
To update the graphics driver:
- Go to My Computer > Manage > Device Manager...look for display adapter (expand)...right-click and choose Update Driver
Send me your 2015 Central Model so I can upgrade it to 2016 and see if it holds...
https://www.dropbox.com/sh/dtw5z4a2wzt2m0p/AAAAyS0hKWahzjpD52Ue_vZ3a?dl=0
gowsautocad
After dealing with the problems I was having downloading Revit 2016 I found out that the PC that I had has a interanl problems in it.  Replaced PC few better PC, More memory space and faster and downloaded Revit 2016 and now is working fine.  Thanks for the assistance and dealing with my Frustrations!!
Thanks - gowsautocad !!
