Revit 2016 textures show wrong file path
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
365 Aufrufe, 2 Antworten
Hi this is my problem, please see the screanshot, the textures show wrong file path, but I have the folder 'Textures' (C:\Program Files (x86)\Common Files\Autodesk Shared\Materials), how can I connect the .png ? Thank you, Federica.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Easy fix...Click on the image's name (just below the image itself) and browse to it's location and load it from there. Are you not able to do this?
Nachricht 3 von 3
ennujozlagam
@Anonymoushello, you can try to check it HERE for the solutions. thanks
