Revit 2016 slow to respond to commands
4 ANTWORTEN 4
Nachricht 1 von 5
360 Aufrufe, 4 Antworten
Hi all,
My name is a Nick and I'm an architecture student, recently I've been having difficulties with my 2016 Revit Program on my laptop (Dell Inspiron Signature Edition with 8 GB of RAM). Most of the time my Revit program is choppy, slow and lagging. I'm not sure if the source of the problem is my computer or the program I downloaded. Typically I cannot perform basic tasks without the software being really slow.
Help would be greatly appreciated.
-Nick
4 ANTWORTEN 4
Nachricht 2 von 5
MostafaElashmawy
als Antwort auf: Anonymous
does this happens with all files or are smaller files are working ok?
Mostafa Elashmawy
Nachricht 3 von 5
als Antwort auf: MostafaElashmawy
This happens with all of the files. Especially if it’s a larger file, smaller files are less glitchy but still move around sluggishly.
Nachricht 4 von 5
MostafaElashmawy
please check below link for recommended specifications based on file sizes:
in my opinion more RAM (16 Gb total) and some SSD (256 Gb) would enhance your device.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/S...
Mostafa Elashmawy
Nachricht 5 von 5
Provide a sample file.
If you've imported or linked CAD files, they are probably the issue here.
Your laptop is weak. Consider getting a proper work machine, you are at the lower end of the specification recommendations.
You browsing is likely due to your weak integrated graphic card, these are not meant for work.
